Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Engine Swap help
Old Jul 30, 2012 | 04:21 PM
ALMARRI's Avatar
Default Engine Swap help
hi guys
i just bought a chevy 1970 C10 truck and i would like to start my project soon,
i need help to chose an engine i was thinking to start with 502 instead the current one the 350,
i was wondering if i need to change the 350 transmission to install the 502 ?
i also looking for a salvage corvitte for my future project anyone can help ?
Old Jul 31, 2012 | 07:02 AM
cambirdracing's Avatar
A 350 tranny will bolt to the back of a 502. Whether it will last is a different story.
Old Jul 31, 2012 | 08:28 AM
quick77's Avatar
The 350 Turbo will work if built with the correct parts. Use the 2nd gear sprag assy. Its not cheap probably 300 dollar range. ATI and TCI both sell them. Behind a big block do not use the hardened outer race. I will crack or break. Only other weak spot is the bellhousing, make sure you're using good motor/ trans mounts. They will live if done right. We run one behind a 467" small block making 800+ HP car runs lo to mid 9s n/a in a 3300 lb. nova
Old Aug 1, 2012 | 11:46 AM
codyvette's Avatar
Talking
Well put. They can even make overdrives hold up to some crazy beatings these days. Its all about how much you wanna spend. Just don't skimp on your trans that fabulous motor will be a wonderful sounding boat anchor.
Old Aug 2, 2012 | 06:36 AM
ALMARRI's Avatar
Thanks guys for responses
I just want to know if it worth to start it with 502 ci without changing the transmission ?
If so, i will swap engines. Is there anything to take care of like harness ?
How would i know the differntional ratio of my truck ? I got the car without any details from the show room I asked them many questions but they don't know nothing about it
Old Aug 2, 2012 | 10:21 AM
Wiring harness on an old truck like that is pretty much straight forward. should work also with out any changes. The only real way to find out the gear ratio is pull the cover, count hte teeth on both the ring and pinion gears. divid the number of teeth on the ring gear by the number of teeth on the pinion gear, this will tell you exaclty what the ratio is.
Old Aug 3, 2012 | 12:57 AM
ALMARRI's Avatar
That's great .. Thanks buddy I will start work on it by next week thanks all
