Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Donovan HC700 build
Old Oct 9, 2013 | 04:42 PM
ArnieVXR's Avatar
Default Donovan HC700 build
I've picked up a 'seasoned' HC700 block, 5.3 crank, BRE rods and a few other bits and pieces. It's an 11.1-inch deck height, so made 706cu back in the day. I want to put together a street motor. What I've read so far suggests I need to be careful about specifying heads and pistons. I'm also wondering if I can use standard casting heads or will have to go for Big Chief style heads. And if I go for the more expensive heads, what degree heads do I need?
I've got loads more questions, so where's the best source of information?
Cheers guys
Arnie
Old Oct 11, 2013 | 03:17 AM
ex-SS-ve's Avatar
I would go for a 14 degree cfe 5.3 bs style head. At this level of a build there should be no reason to compromise it to some production cast bbc head. Shoot me over some specs of this build and ill do what i can to point you in the right direction.
Old Oct 11, 2013 | 09:15 AM
cambirdracing's Avatar
Some thing that massive, you really need to start here: http://www.sonnysracingengines.com/
Old Nov 7, 2013 | 09:55 PM
uxojerry's Avatar
I assume this engine is 4.6" bore and standard bore spacing? For a street motor a big set of conventional heads will work. AFR 385s come to mind. Dart makes a 11.1 tall deck also. They can sell you an intake. You could easily build a 1000hp engine with shelf components. Have fun!!!
Old Jul 20, 2022 | 03:50 PM
Shitheadsteve69's Avatar
Did you finish this build?
