Need help tuning a 454
Just bought a 72 Camaro with a 454. Don't know much about the engine, except that it is a crate motor. It had an old Quadrajet intake and carb on it when I bought it. For some reason, the intake ports were slightly too small and blocked the secondaries on the carb from opening. I picked up an Edelbrock RPM Air Gap intake and Performer 750 carb. I installed both and did not do anything to the carb out of the box. The timing tab on the timing cover was all ripped up, so no notches were visible, but "before" and "aft" were visible. Using these two indicators as a guide, I timed the motor to what I believe is 10 degrees. The car idles fine, but when I took it for a drive and hit the gas to open it up just a little, it stuttered so bad that it through my head back and forth. The car accelerates, then feels like it gets completely starved for a split second, then accelerates again, then stops again, all through the RPM range. I don't know much about getting these motors dialed in after swapping parts, so I need some help. Don't know if it's a carb issue, timing issue, vacuum issue, or all of the above. Need some lessons on troubleshooting. Any help appreciated.
