Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
305 timing mark question
Old Jul 2, 2014 | 08:47 AM
Isaiah_13's Avatar
Default 305 timing mark question
So the machine shop/ engine builder put the bottom end of my 305 together for me. Did a great job. My question is, he put cylinder one at top dead center, and the crank sprocket dot is at 12 o'clock & the camshaft sprocket is at 12 o'clock. Always thought that the crankshaft is suppose to be at 12 o'clock and the camshaft at 6 o'clock?
Old Jul 2, 2014 | 07:39 PM
fleetmgr's Avatar
Barring some weird timing set, you're right. However, don't expect the timing marks to line up every time you rotate the engine 360 degrees. If you crank it around long enough, they should line back up.
Old Jul 2, 2014 | 10:02 PM
v8sten's Avatar
dot to dot is not top dead center that is bottom dead center, #6 firing position.
Top dead center is when both dots are at 12 o'clock
Sorry fleetmgr you are wrong
Old Jul 2, 2014 | 11:23 PM
fleetmgr's Avatar
Sorry, no I'm not wrong. When installed, they go dot to dot. One full rotation puts them at 12/12, then you can drop the distributor in.
Old Jul 2, 2014 | 11:57 PM
v8sten's Avatar
this makes it sound like you think dod to dot is tdc when it is not
there you go, here is a more detailed explanation. which is what i said earlier
Old Jul 17, 2014 | 01:39 PM
Isaiah_13's Avatar
I was told that if they marks are apart that this 180 degrees out? Is that right?
