Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
95 z28 spit and sputter problem
Old Oct 1, 2014 | 06:23 PM
king karny's Avatar
Default 95 z28 spit and sputter problem
OK.....so 95 z28 m6 137000 stars and runs OK....as long as I can keep her cool she has no problem. Thus started over this past winter doing pizza delivery when I would get back to the shop I'd shut the car off go in grab next order 5 minutes tops I'm back in car starting it. She fires up but before I can leave the parking lot she's kicking and carrying on like there's no spark then no fuel and I have to lay on the pedal to keep the engine running trying to keep it at high rpms. If I do this while limping down the road she will eventually even out and act completely normal. So I thought it was the opti. I replaced that recently along with water pump and wires and harmonic balancer. I drove a few days ago about an hour and a half to Philly ran good whole way till I shut the car off for 10 minutes then it did thus again. I pulled over and let her sit for another 20 minutes. Started back up and was OK I could tell the issue was still there but it was fading away and running back to normal so I got home asap. Now Im wondering when it sits the temp gauge will be in one spot then when I turn the key on the gauge will go up a bit higher then what it was when I shut down.....could residual heat from the car be messing it up??? If I drive at night the motor doesn't get hot enough for this to happen unless I make the motor hot by turning off my fans. .... Please someone help lol
Old Oct 2, 2014 | 09:54 AM
unforgiven's Avatar
First question, why are the cooling fans on a switch? Next, is the check engine light coming on?
Old Oct 21, 2014 | 02:56 AM
king karny's Avatar
They r on a switch because when it gets overheated they don't turn on. It used to be one if them but now both quit but I did the water pump and thermostat is gone I did that in the summer during troubleshooting sessions on the car bleed the **** outta the system still overheated. No check engine light just brake and security I only get check light when I'm in 6th going up a small incline on the highway and trying to stay at 70 with minimal pedal usage .
