Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
cam selection help
Old Dec 1, 2014 | 09:24 PM
4200chevy's Avatar
Default cam selection help
I'm new to this forum and this is my first post.i have a 66 c10 swb.trying to pick a cam. Truck has 355, flat tops,186 humps with screw in studs and pocket ported,650 holley, torker 2. Or performer intake .I have both.truck has 373 gearing th400, stock converter truck weighs 3500 with me in it. I'm really new to this stuff.i have helped my father build small blocks in the past.but sadly most of it went in one ear and out the other.i want a cam that has a very Lopey sound. But I have pb,ps,vacuum advance and vacumm secondarys.so still needs to make enough to run the items listed.oh yeah and my current setup is hydraulic flat tappet.and because of prices that's what I want to stick with...Thanks for any help
Old Dec 1, 2014 | 09:56 PM
68SSJARHEAD's Avatar
I can tell you a great cam for what you are talking about.....but you will need to upgrade a few things....are you willing to do that.....???
Old Dec 2, 2014 | 05:05 PM
4200chevy's Avatar
I'm willing to upgrade some things.not a problem.ive been hearing that I need to run a higher stall?
Old Dec 2, 2014 | 11:22 PM
http://www.compperformancegroupstore...gory_Code=HFTM
check these out....I have the 280H cam and I love it. Havent got to run the car at the track yet....but similar builds are running anywhere from high 11's to mid 12's.....jus click the diff cam and it will let you know what supporting mods you need
Old Dec 3, 2014 | 08:22 PM
cuisinartvette's Avatar
flat tappet or roller?
FT I wouldnt go any bigger than an Isky 270 mega cam
They are old but work and run hard will work with a stock converter but would recommend one a little larger like a 2400 or so. Keep the performer intake
It will have enough lope to let others know you got something cooking, pull hard and operate PB just fine.
