350 vortec help!
First - no, this will not hurt your transmission if you do not change out your converter. However, this isn't good for the engine (which probably cost more than your transmission). Changing out the torque converter will not require the transmission pan to be dropped. It's a bit tedious to get the transmission out, but swapping the torque converter should be easy. If this is a daily street driver, I'd look at like a 2,000 rpm stall converter (I doubt you're racing or you wouldn't have used the stock low stall converter, ha). I don't know what transmission you have, but be aware of torque converter compatibility due to PWM, TCC lock up strategy, etc.
Second - the torque converter might not be the problem. It could still be a bad tune in the computer at the lower engine speeds. This actually brings up a question - did you have the ECM tuned for the new heads/cam combo? If you didn't yet - I'd do that first before the torque converter.
IMO, if you switch out to a 2k stall converter, you'll like the illusion of a better engine.
Haha, yeah - try that first.
Actually, you might want to check out swapping to a 0411 ECM (often called a LS1 ECM) to control your engine. I don't know if you're looking for another mod. But the 0411 can be flashed with the 2000+ Express 5.7 Vortec calibrations to run a '96-'98 L31 vortec 350. (This is a somewhat popular mod for those owners who have a '96-'98 Silverado.) This is something I'd discuss with your tuner about. (Might even be much cheaper to tune to 0411.)
Or if you already have the 0411, then you're set! Get it tuned!
Let us know how it turns out.
As for the 0411 ECM - I'd suggest you talk with your tuner. There is much more support for the 0411 ECM, but maybe your tuner doesn't mind working with the ECM you already have. The 0411 ECM is so plentiful in junkyards and can usually be picked up from some kind of U-Pick-It or whatever for about $40.
Supposedly, the 0411 calculates engine demands much quicker than the blackboxes of '96-'98 and supposedly helps with a little better throttle response and little more smoother idle. But a surging/bucking idle won't be fixed without a tune regardless of the ECM used.
The 0411 swap is not difficult and can be performed cleanly enough to look almost factory. Some say the Black Box can run just as well and make just as much power...That may be true at WOT, but during transients and part-throttle operation the 0411 blows the Black Box away in driveability, throttle response, transmission shifting, and fuel economy.
