Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Valve spring seats
Old Jun 4, 2019 | 08:46 AM
Noaht4's Avatar
Default Valve spring seats
I'm putting together some heads for a Chevy 350, they're blueprint engines aluminum heads. I had to change out the springs and retainers because they didn't work with the cam I have and I also want to switch to the 10 degree valve locks. I need to change the valve spring seats too because they don't work with the inner springs I have. I need to know if I should be getting the cupped valve spring seats or not? What's your opinions?
Old Jun 17, 2019 | 10:03 AM
pxl2562's Avatar
You can get the valve spring seats (or locators) with external or internal locator ridges. Personally I would definitely suggest making sure you get a seat that positively locates the spring, but whether the locator is external (on the spring OD) or internal depends more on the size of the spring, whether there is a damper or internal spring, and the clearance you're working with.
Old Jun 18, 2019 | 08:07 AM
biketopia's Avatar
Have you called up blueprint? I have one of their long blocks and called a few times and talked to tech support and they were very friendly and answered my questions, they should be able to point you in the right direction.
