Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Sbc 355
Old Oct 17, 2019 | 06:51 AM
Freddy Bechtol's Avatar
Default Sbc 355
I have a sbc thats .030 over bore. It has hydraulic lifters, flat tappet cam and roller tip rockers. It came stock with a .041 gasket thickness. And already have pushrods for that thickness but is it possible to go to a .036 gasket to get a better quench with the same pushrods or do I have to remeasure pushrod length. And would it make a big enough difference in motor efficiency to worry about going through the trouble of measuring for new pushrods??
Old Oct 18, 2019 | 03:17 PM
Gojira94's Avatar
Better choice would be the Mahle/Clevite/Victor-Reinz 5746 (.026" compressed thickness).
https://www.summitracing.com/parts/mah-5746
If all you're doing is swapping gaskets with no milling of the heads, you're only making a change of .015" with the thinner 5746, which is way short of 'off the shelf' pushrod increments of .050".
Old Oct 25, 2019 | 02:34 PM
MuhThugga's Avatar
Find out how much your pistons are in the hole. If they are the standard .025, get a .015 or .020 steel shim gasket from Fel-Pro for the ideal .040-.045" quench.
Always measure for the proper pushrod length after any change to geometry is made.
