Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Water down intake and carb
Old Dec 29, 2019 | 09:33 AM
jt_2002_ta's Avatar
Default Water down intake and carb
Ok, so we had a disaster last night! Me and my son are building him a 68 c10 with a sbc. I was starting the truck and it had a backfire through the carb and had a little bit of fire. Well my son ( he's 9!) Bless his heart, he had a cup of water in his hands he was drinking and when he saw the fire he got worried and threw it on the carb and it got down the intake. Fire is a touchy subject since we lost our home to a fire a few yrs ago so he just reacted.
Long story short, wont start now. I've pulled plugs and cranked all the water out, changed the oil, marvel mystery oil down cylinders, stopped all the water out of the intake.
Any ideas what I can do? It's got spark. I'm stumped
Old Dec 29, 2019 | 09:52 AM
LLLosingit's Avatar
Water shouldn't have done any damage if you didn't turn it over with water in the cylinder and if you did turn it over it still may be fine if it wasn't enough water to hydro lock the engine. I would try new plugs first and recheck the initial timing. If it's a Holley carburetor you may have blown the power valve when it backfired through the carb.
Old Jan 13, 2020 | 09:32 AM
Enigma540's Avatar
Might try pulling the distributor cap off and drying the inside out well too, in case any of it found its way inside there or the plug connection if it's an HEI.
Old Jan 13, 2020 | 09:44 AM
SS RRR's Avatar
Village Troll
check to see if you're getting fuel and ignition. If you've already emptied the cylinders of water then put the plugs back in, spray a little fuel or starter fluid through the carb and try to start it.
Old Mar 8, 2021 | 11:53 AM
solidaxel's Avatar
Be careful with steam cleaning engine compartment!
