Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Doing a LS Swap! Need Help
Old Jan 20, 2020 | 10:34 PM
mtz1933's Avatar
Default Doing a LS Swap! Need Help
So I am hoping I can do a Modern drivetrain swap into a 56 Chevy Bel Air. I have an opportunity to purchase a motor, transmission, harness, and pedal out of a rolled over 2007 Chevy Silverado 2500, that ran good and had low miles before the accident. I was offered all the parts removed and ready for me to load and bring home for $1100.
So here is where I am caught up! It’s a truck motor! Or does it really matter? Car or truck? Also from the little bit of research I did, in 2007 this 6.0L seems to have some changes to it, but there is a lot of differences of opinion on what’s good and bad! Can anyone give some basic specs on this motor/trans combo and what I might need to also consider before the truck goes to the crusher after we pull the motor! I opted for this route because I have an older 1965 327HO SBC, but in order to get as close to the desired 400hp, it will cost a lot more than $1100.
Any advice or suggestions are appreciated!
Old Jan 21, 2020 | 11:39 AM
biketopia's Avatar
Best bet is to post in the swap forum, they'll be able to answer up your questions. Real quick though, the engine, accessories, trans, gas pedal & harness, and ECM and engine harness should be all you would need.
