Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Flex Fuel Injector Question
Old Jan 24, 2022 | 03:00 PM
SOMT's Avatar
Default Flex Fuel Injector Question
I'm sure this has been asked before but I'm having a hell of a time finding good answers on this. I see plenty of info going from regular pump gas over to e85 but not much regarding the opposite. I currently have the flex fuel injectors on my L59 5.3 intake but have no interest in running e85. I'll be running a terminator x for tuning and just need to know if I need to swap injectors in or can I keep the flex fuel injectors and just have the motor tuned for 93.I know the output on the flex fuel injectors are higher than the normal multec 2 style injectors.
Old Jan 24, 2022 | 03:25 PM
pdxmotorhead's Avatar
I have the same injectors on a L33, they work great ,, they are only like a couple lbs more flow base than the "stock" 5.3 injectors..
IMHO almost perfect for a close to stock tuned motor. And they are already alcohol safe so the normal E10 pump gas wont hurt them..
Old Jan 24, 2022 | 05:11 PM
RedXray's Avatar
If you have the plastic rails the injectors flow 33lb/hr at 50psi (return system)
Stainless rails flow 36lb/hr at 58psi (returnless)
Good injectors up to around 430/450 wheel
Old Jan 24, 2022 | 06:38 PM
SOMT's Avatar
Awesome, thanks guys. This is going in my e36 swap so I'll be going with a return-less system. Going to use a corvette FPR.
