Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Roller Conversion Cam in a Roller Block?
Old May 3, 2023 | 11:16 PM
64GunPilot's Avatar
Default Roller Conversion Cam in a Roller Block?
Will it work? Found the cam I'd like for a pretty darn good price, but its a "roller conversion" camshaft. My block is an L31 roller block. I have read you can put a flat tappet camshaft in a roller block without much fuss. But not sure if a "conversion" camshaft will work in a roller block. Thanks in advance.
Old May 4, 2023 | 09:55 AM
bthomas's Avatar
Will be a flat nose cam instead of a step nose. Also there is a fuel pump lobe added.
you’ll need an earlier style timing set, a spacer to replace the retention plate, and run a cam button/or roller button cover
personally I’d get the correct step nosed cam as it’s a superior retention design.
Old May 4, 2023 | 10:06 AM
64GunPilot's Avatar
I see. That’s a bit too much Frankenstein for me. Just thought for the price….
anyways thanks for the reply. I appreciate the advisement!
