68' camaro start issue
Thank you in advance.
Looks like some gas but actually pretty bone dry. If I pump the cylinder very minor amount of gas is visible entering
You could use some low pressure air to blow back through the fuel line to be sure there are no leaks where the fuel pump could suck air.
While line is off inlet side of fuel pump, you could have someone crank the motor and use your finger seeing if there is suction at the pump (if no helper, maybe try a bottle with some gas in it, and a hose from fuel pump to bottle to see if it gets sucked up)
Fuel tanks are easily gummed up and can get rusty quickly as well, due to ethanol. Just a couple of ideas…..
Does it have the block mounted mechanical fuel pump? If so unhook the out fuel line, put it into a can/container and crank the engine, it works off the camshaft. When block mounted mech pumps fail, sometimes they pump fuel into the engine itself. So check your oil. The drive lobe on the cam or fuel-pump-pushrod itself could have failed also.
With a 383 I'd expect it to have an aftermarket mech fuel pump, some are rebuild-able.
My old ratty drag 68 from long ago.
