Future Project planning
I plan on being able to drive the car on the street (good weather, shows, and strip).
i think that's because there isn't a quick and easy answer to give you, but i'll try and help. suspension can wait, unless the BB pushes the nose into the ground. then i would do the front struts and custom ordered springs next. fuel delivery should be easy. cooling system is just a good pair of elec. fans and look into someone like Be Cool, Afco, Griffin (sponsor), and others. BMR makes a K-member that will bolt in directly, or you can get a front and mid motor plate from APE or Madman, both sponsors, to bolt right in after you weld in the mounting brackets. firewall does not need to be touched, but someone else needs to chime in about the cowl area (windshield overhang), because i'm still trying to figure that one out myself. i think in ALL cases an area needs to be cut out, but the part i don't know about is if anyone has been able to retain their passenger side windshield wiper?????? of course you're gonna want to step up to a th 350/400 or glide, unless you want to go 6 speed. BMR also makes a crossmember for the trans to just bolt right in. i don't know if i need to put that in first with the trans, and then allow that to determine the location of the engine location. also not sure if you can keep your power brake booster????? i know i can with a small block. then there are some, members and Madman, who can help you with your header part numbers. you'll have to have a shop fab up the rest of your system from there. hope this helps you out some. it's not a 1,2,3 done project, but it's not that hard from what i've been told. keep an eye on my homepage on here from time to time as i am making a photo diary of each step of the way. good luck, it should be a lot of fun and a big reward at the end.
later,
Dave
Thanks
later,
Dave
