Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
solid or polyurethane motor mounts?
Old Mar 9, 2005 | 02:41 AM
OnE Ls1 2 HaTe's Avatar
Lightbulb solid or polyurethane motor mounts?
i was just wondering if i should go with solid motor mounts on my 67 camaro? the guy from summit said i would be much happier with polyurethane mounts. what do u guys think?
Old Mar 9, 2005 | 06:56 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
solid mounts always transfer more vibration than poly or rubber, but they are stronger as well. It depends on what the car will be used for. I have solid mounts in my Nova, and I don't mind the vibration (not all that much). Polyurethane are much better than rubber, so if it's a mostly street car I'd go poly.
Derek
Old Mar 9, 2005 | 07:35 AM
well it has a big cam , and all and im gunna use it to street race if i do go solid do i use a solid motor mount too?
Old Mar 9, 2005 | 12:34 PM
7 Second Club
I'd use solid mounts if you want the best holding power, or you can use the polys along with a limit strap of some sort to control movement.
Derek
Old Mar 10, 2005 | 08:47 PM
thebowtieislife's Avatar
make sure your trans mount matches your engine mounts, poly with poly, solid with solid
Old Mar 10, 2005 | 09:40 PM
7 Second Club
not true. you don't want to run a solid trans mount with solid motor mounts, otherwise you're looking at a possible cracked transmission case. you still want a little give, and run a poly transmission mount if you go with either poly or sloid motor mounts.
Old Mar 11, 2005 | 05:21 AM
really. well i got a new poly trans mount. sould i use a limit strap on it? by the way what is a limit strap? thanx for the info.
Old Mar 11, 2005 | 06:53 AM
7 Second Club
a limit strap is used on the engine only. It is used on applications without solid mounts to keep the engine rotation to a minimum, and to keep the mounts from breaking. the transmission mount should need a limit strap. I'm running Moroso solid motor mounts and an energy suspension poly transmission mount on my Nova, and have had good luck with them.
Derek
