Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
what crank is better?
Old Mar 13, 2005 | 10:34 PM
eric01ss's Avatar
Default what crank is better?
which one is better a 4340 or a 4140 crank and why? also how much power can a 5140 crank hold?
waht crank type holds the most power?
Old Mar 14, 2005 | 12:47 PM
nosfedgta's Avatar
a 43040 forge piece is the strongest crank you can get, besides a bilett crank
The 43040 forging is stronger than the others.
A 5140 can hold good power depending on the rest of the setup. Good Bolts, rods etc.
Old Mar 16, 2005 | 06:00 PM
Bryan TTM's Avatar
Crower
Old Mar 17, 2005 | 05:58 PM
crow2's Avatar
We of course like the 4340 material! I agree that the CROWER crankshaft is definitantly one of the BETTER cranks,We also think that as far as a inexpensive crank like the EAGLE crank.How much power are you putting out.That would be helpful to know!Callies cranks are great also,but it really depends on how much you want to spend.GM'S 5140 cranks were good up to 600hp or so!Hope that helps!
Old Mar 17, 2005 | 06:21 PM
eric01ss's Avatar
it is a scat crank i was truing to get info and the rods are scat h-beam w/ ross flat top racing pistons and for a 420sbc that will have the bottle on it
Old Mar 17, 2005 | 06:42 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
which one is better a 4340 or a 4140 crank and why? also how much power can a 5140 crank hold?waht crank type holds the most power?
Specifically, what motor are we talking about here? sbc, LT1, LS1, BBC, other?
Old Mar 17, 2005 | 07:05 PM
eric01ss's Avatar
its a sbc chevy
Old Mar 17, 2005 | 07:15 PM
thebowtieislife's Avatar
if you can afford it a non twist oliver is the best way to go
Old Mar 17, 2005 | 08:11 PM
Mangled03gmc's Avatar
Baltimore Whore
4340 is probably the best but they will break before they will flex.
Old Mar 17, 2005 | 11:25 PM
CTSV05's Avatar
I might be a bit nervous of spraying the Scat too hard.
Old Mar 18, 2005 | 08:28 AM
eric01ss's Avatar
why7 would u be nervous of spraying
Old Mar 21, 2005 | 12:51 AM
Keith's Avatar
How about a forged 1053 steel crankshaft?
Old Mar 23, 2005 | 08:32 PM
Baltimore Whore
4130 is probably the best
