427 SBC Question
any information on this matter would be greatly appreciated.
Thank you
If you are stuck on using a stock block, then find a 400, SBC. They typically came in trucks, Impalas, station wagons, and some chevelles from the early to mid '70's. A lot of people feel a 2 bolt is actually stronger than a 4 bolt main 400 block, depends on which theory you buy into and how much power you are trying to make. By the time you get done prepping one and making sure it is good, then you would be near the cost of a after market block. Jegs or Summit sells a bare block starting at $1800. You can find them on Ebay for a couple hundred cheaper. If you are not the engine building type of person, then I would look at getting a crate motor for that size of motor. They run anywhere from $7-12K depending on how wild you want to get. Remember speed costs money so.....a good 383 would be cheaper and its real easy to make 450hp and remain streetable.
383s are great all around motors, good TQ and HP. Plus a 350 blk is way easier to find.
Your goals and intentions will help us to help you.
