Anyone Else Having Problems Sealing... Up their head studs?? I have anti-freeze in my spring area again, but on the other side of the motor!!!! Oil is clear, just under the valve cover. |
u need to put sealer on the threads. like teflon putty or somethin like that. just go to the local speed shop and ask. |
I did, both times. |
Originally Posted by CTSV05 I did, both times. |
Do you have scerw in rocker studs? I had to use sealer on mine. |
Originally Posted by Muffracing Do you have scerw in rocker studs? I had to use sealer on mine. I had no problems until I switched to head studs. Same heads, then and now, last fall, it was on the pass. side , now its the drivers. And no I didn't swap heads, as the holes in front only allow me one way to install. |
Could be the install of the studs. Did you leave it sit for a while after installing the studs and then torque the heads down later. This will make the already dry sealent crack and make for leaks. |
© 2024 MH Sub I, LLC dba Internet Brands
