Open or closed Air cleaner?
Regarding my 85 Chevy Impala, I say that an open Air Cleaner allows more air into the carb. HE says that the air going into the carb with an open Air Cleaner installed is going to be hot air, since the open air cleaner basically takes in the air from the engine compartment and can't be routed there from anywhere else, by design. The stock Air cleaner works better in his opinion.
What do YOU say?
Just my $.02
Derek
Just my $.02
Derek
When I do swap out the engine, I'm sticking with a carbed setup so if you say open Air cleaner is better, I'll stick with that, after getting one. I was looking at an Edlebrock 14 inch tonight, then read the small print that says- "not for sale or use on pollution controlled vehicles. I know I have to test for emmissions next year and since I don't have OBD II in this car, they're going to look for the emmissions equipment. I figure I can swap out the Open Air for the stock before testing. Your thoughts?
Derek
I got the Edelbrock Pro-Flo 14" Open Air Cleaner. Will get the K&N filter in a day or two. It turns out that this open Air Cleaner has holes for both my PCV Valve and the tube coming from my Air Reaction Injection (AIR) system, so I should be fine for emissions with all my tubes hooked up.
I'll have more questions for you later. Thanks again.
