Looking into a 524ci stroker kit
That's a similar setup as to what I was thinking of running. Crazy that you say that stuff. Except for the AFR heads I was considering the BMF heads that they offer in jegs since they come with a spring with a max lift of .880" I can use a big cam. Even the cam, I was considering something similar. About the vacuum pump, I plan to run this motor on the street at least on the weekends (the local cruise and what-not) and I read up on the pumps and they said they're not really not meant for the street so I'm not sure. That and they're expensive
. Thanks for the help. a relatively easy 496 combo...
14:1 ish compression
AFR 357cc heads
ported Super Victor
1150-1250 Dominator
(Preferably tunnel ram with dual carbs)
2 1/4" primary header
Custom solid roller probably high 270's low 280's at 0.050"
"Around" .800" lift
Grant it, you could even run the 335's or some Darts and probably hit 900 with a vacuum pump...will make the power even easier on the 357's. That is about as general a statement as can be made, as I do not know the specifics of the ENTIRE set-up. If you seriously want my recommendations and help, might want to PM me, I will be more then happy to give more info.
p.s. i dont use a vacuum pump just a canister and i dont even have that hooked up yet . drive it every where with iorn heads and stock radiator and it runs a 190 degrees at the most
oh and what size tire is the guy running on the camaro ??
And you said what I wrote was the stupidest thing you have ever heard??? Are you actually saying a stock headed (Ported or not) 12:1 motor is going to make 900 hp?????? you cant be sober AND serious....I didn't mention an E.T. I mentioned a power level, your an idiot, learn to read then repond with something that makes sense to what you are trying to discredit for some unknown reason (Why is that again?).
And you mentioned a Vacuum canister....what does that have to do with a vacuum pump? Have you ever built a REAL motor? Let's see,
Vacuum pump: Creates CRANKCASE vacuum to allow rings to seal under extreme internal pressures and windage.
Vacuum Canister: so you can run power brakes with a healthy cam......why was it you compare them again? (Or brought one up with another?)
Why are you talking about a combination that you admittingly haven't proven yet, Why did you join the conversation with nothing but an unproven opinion to add? Don't know if you noticed, but me and 69 chevy are on the same page.
As you reference suspension, that is subject to the vehicle and application, I doubt you would believe me but there may be people trying to listen.... try a 68 Firebird with a small block using STOCK rear leafs, 50/50 in back, 90/10 in the front with Moroso trick front springs, no sway bar going 11.00's on the motor and 9.60's on spray (Quarter mile of course). In the neighborhood of what you would need for 6's in the eight.....bet it put out more then a ported stock head 12:1 big block? you'd be right. If he had better suspension and drivetrain would he have gone faster? yes! Would it be as easy to bolt back in the sway bar and remain relatively comfortable to drive around town, probably not (Unless you got into ridiculous money). What I am trying to point out, when it comes to ET you have to look at more then just power, that is why I addressed the power output alone, because there are less variables.....he asked a question, he got an answer, and please do not attempt to tell anyone your motor makes with-in 150hp of 900, unless you left out a blower or something....
BTW 69chevy, I checked my Paypal, where's it at, LOL
. So having a wild motor as a daily driver shouldn't be a problem There's no bashing here, just facts about me. Let's just say that I'm driven by the passion for cars.The paypal didn't go through?
. but i dont see the point of having to run a pump just to get your rings to seal, its stupid . refering to what you said about me not doing this much if your talking about race motors then your right . i dont build race cars only street cars . i dont see the point of having **** like that on a street car so there for i dont car for that stuff . and now as for my heads . you shouldnot be saying anything about them . yes they are a set of " stock" iorn heads that have been sent to air flow research and had a large about of work done to them . so you really cant say **** abuot my heads
oh and if your going to give definitions for parts makesure you get it right . the pump doesnt create high internal pressure . it makes a large amount of vaccuum pressure in the crank case to help seal the rings when you run LOW tension rings . no need to run them if your using a high tension ring
Sooooooo, once again, great point! You might want to re-read all of what I said to you, it goes over how to read, then post. Helps to keep you from looking like a jackass....
wanna try again....
Wow, that is amazing, trust me when I say 320-330 is good for a stockported head and I do not doubt it....are they going to support a 900hp N/A 496, uhhhhh NO! Do me a favor, call AFR today (Or any other manufacturer for this point to be made) and ask if they hold a candle to what is currently offerred, any guesses on the answer? how is that 220 cfm exhaust port treatin ya?
We used a new 200 bucks crank ( don't even remember the name of the crank ) eagle rods , and je piston . The combination was 4.250 stroke and 4.320 bore ( .070 over ) . We put milodon splayed caps . The cam was 266/276 dur@.050 and close to 700 lift which is prety small for that CI but this guy wants to have street machine . The compresion was 11:1 . This engine pulled over 7 grand with no problem and made peak power at 6900 rpm . if you have good heads , you make good power . So spend some money on good heads .
Later
Later
. That's not a bad sounding motor though. Sounds like a bad enough street motor to scare some people.
