Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Building a mini mouse motor that can
Old Jun 3, 2006 | 04:29 AM
Turbonoma's Avatar
It's finally running. Had to buy a new fuel pump, starter and last but not least a new battery.
My neighbor brought over his battery charger and that's how we got it started. Stuff goes to crap if it sits too long. PEACE>Tony
Old Jun 12, 2006 | 09:40 PM
Turbonoma's Avatar
Default Running again
Installed the battery and it fired up. Idles rough and I have to feather the throttle to keep it running. Efans aren't working so it got hot real quick. Afr is 18.8 and fp is 38lbs. Tried putting it in gear and nada. Well at least there
are no leaks so far. Alot of issues still to deal with but I'm motivated again. PEACE>Tony
Old Jun 18, 2006 | 07:43 PM
Nate81Camaro's Avatar
updates??
Old Jun 20, 2006 | 06:59 PM
Turbonoma's Avatar
I was able to use my tunercat program today. I'm sending the file to Frank aka Revolution so he can make a new program for me. Thanks for asking Nate. I'm getting closer to hitting the street and sneeking up on some unsuspecting victims. PEACE>Tony
Old Jun 20, 2006 | 08:37 PM
cool bro - let us know what kinda numbers you put down (if you are to get it dynoed)
Old Jan 14, 2007 | 11:12 PM
Turbonoma's Avatar
Finally got back from my holidays trip to Florida. Hung out with Justin aka "Leadfoot" over in Tampa. Well I went and started up the engine and to my surprize it remained idling. Before I would have to keep my foot on the gas peddle at around 1700rpm or it would die out. I think the ecu is still on a learning curve. I did unplug the maf so it would start up running on speed density. Later I plugged it back in while still running and it remained the same. The wife just bought a new vid camera and I'm going to record some footage for you guys that have been patiently following my house of pain. PEACE OUT>Tony
Old Jan 15, 2007 | 02:42 AM
xpndbl3's Avatar
www.s10forum.com is a good site for any issues
Old Jan 16, 2007 | 09:31 PM
Turbonoma's Avatar
Had some computer problems today and I also had to go out and buy a fire wire cable cause the new camera didn't include one. I'll try uploading the vid tomorrow. PEACE OUT>Tony
Old Jan 17, 2007 | 06:46 PM
Turbonoma's Avatar
Default The TurboNoma project
Here is my turbo project. Tell me what you think. PEACE OUT>Tony
http://www.youtube.com/watch?v=0a_hrcoldtY
Old Jan 28, 2007 | 05:46 PM
Turbonoma's Avatar
If the torque converter were not engaged properly to the trans, will the truck not move when put into gear(drive)? Would I hear some sort of noise that would indicate a problem. Fluid level seems ok.This is my situation at present. PEACE OUT>Tony
Old Jan 29, 2007 | 12:09 AM
My01SSCamaro's Avatar
that could be a posibility when you dont get the converter engaged correctly the converter will stick out and when you bolt the tranny back to the motor it there is not enough room for the converter so it just pushes the converter into the tranny and it will break alot of stuff inside, as for noise i dont think it will make a noise it might but a friend of mine did this same thing and his didnt make anynoise when it was running it was just like it was in nuetral all the time, hope this helps
Ryan
Old Aug 1, 2007 | 01:24 PM
  #32
Turbonoma's Avatar
Well I solved my tranny problems. Now I'm in the process of swapping out my stock intake for the modified 2114 Edelbrock. Just need a few misc. items and my tb bonnet back from Sam and I'm done. PEACE OUT>Tony
Old Aug 1, 2007 | 09:21 PM
  #33
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Looks good! Keep the updates coming. Any dyno pulls or track passes yet?
Old Jan 4, 2008 | 01:56 PM
  #34
Turbonoma's Avatar
Default Back at it again!
The new intake is in. Just need to finish hooking up some stuff and it should be ready to test. Using 65# injectors.PEACE>Tony
Old Jan 21, 2008 | 09:14 PM
  #35
Turbonoma's Avatar
Had to rearrange the fpr/coil setup to solve the dizzy clearance problem. Alot better now. PEACE>Tony
Old Jan 24, 2008 | 12:42 PM
  #36
Turbonoma's Avatar
Well guys the 2114 install is 99% complete. Waiting on fittings to finish hooking up the fpr to the fuel rails. PEACE>Tony
Old Feb 1, 2008 | 05:01 PM
  #37
Turbonoma's Avatar
Default Edelbrock 2114 is done!!!!!!!!!!
Well it's finished and it came out swell. Great big thanks to my buddy Sam aka gotswrv who thought of all the little sh*t. PEACE>Tony
Old Feb 13, 2008 | 08:27 PM
  #38
Turbonoma's Avatar
Got a cal. file from Sam aka gotswrv and I'm gonna install it tomorrow and see if it starts up. I'll have a vid soon. PEACE>Tony
Old Feb 15, 2008 | 03:38 PM
  #39
Turbonoma's Avatar
I downloaded the cal.file. The engine turns over but won't start. Need to check the usual stuff first like timing,spark,and making sure the injectors are working.
PEACE>Tony
Old Feb 21, 2008 | 06:39 PM
  #40
Turbonoma's Avatar
Found a gas leak on one of my hard fuel lines. Plugs are dry.Need to verify the dizzy and check for voltage at the injectors. Rome was not built in one day but this is killing me. PEACE>Tony
