Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Roller to flat tappet
Old Mar 30, 2006 | 09:55 AM
white1's Avatar
12 Second Truck Club
Default Roller to flat tappet
I have an old truck (76) and a 92 model 350 vortec for it. I'm gonna put a carb on it, and change the cam, I know a decent amount about these engines, but I dont know whats required (if anything) to go from the roller cam to a regular flat tappet. Besides of course changing the lifters. Can someone help me out. Thanks
Old Mar 30, 2006 | 11:28 AM
chevy123's Avatar
I might be wrong but the lifter bores in those engines are machined for roller lifters only. But if you are still able to use a non roller lifter you will have to check your pushrod length and depending on the cam you might have to change valve springs. And change your timing chain and gears. Thats all that I can think of. Hope it helps.
Old Mar 31, 2006 | 06:03 PM
JPMuscle's Avatar
Why not jus leave it a roller??
-john
Old Mar 31, 2006 | 06:17 PM
white1's Avatar
Trying to build it budget. Its just gonna be a cruiser, nothing to drive everyday.
Old Mar 31, 2006 | 07:24 PM
JPMuscle's Avatar
Ah ok, You should be fine as long as the Dia. of the Lifter is the same, then you would have to look at proper pushrod lengths and associated Vavletrain components.
-john
Old Apr 3, 2006 | 04:09 PM
DeltaT's Avatar
I have an entire package that you might be interested in, for $1225.
Scroll down to the For Sale section on my site.
In package:
- Ported ZZ4 Aluminum heads w/1.6 Comp Cams Roller Tip Rockers
- CC hardened guideplates
- Port matched manifold
- Built Edelbrock Q-Jet w/many tuning parts
- ZZ4 (or ZZ3, the same) cam
- Roller lifters, pushrods
- Dual snorkle air cleaner w/K&N
- Q-Jet NOS Cheater Plate
- Canton Racing phenolic carb spacers
- More!
All for $1225. This would give you at least 375HP/419Torque.
http://home.mindspring.com/~jim_fisk/id1.html
PM if interested.
Regards,
Jim
Old Apr 3, 2006 | 10:09 PM
redbandit98's Avatar
A 92 wasnt a vortec or a roller engine was it? i thought that was still a tbi engine with a flat tappet?
Old Apr 3, 2006 | 10:54 PM
white1's Avatar
Hmmmm I thought they went to roller cams in 87 with the centerbolt valve covers and one piece rear main, but I could be mistaken.
Old Apr 4, 2006 | 09:07 PM
91Z28's Avatar
You are right.
