Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Throttle body backfire!
Old May 11, 2006 | 10:28 PM
buttermantoast's Avatar
Default Throttle body backfire!
I have a 383 chevy with a tpi off of a 90 model corvette. When i first installed the tuned port it ran fine had plenty of power at about 500 miles I developed a exhuast leak drove for about a week and a half and corrected my exhaust leak when corrected i noticed that my motor was backfireing through my throttle body. I tried adjusting ignition timing as well as vavle timing to no avail. Thinking I burned a valve in my head i removed my heads and replaced with edelbrock E-Tec heads and installed a carburator first crank i noticed it was backfiring through the carburator at idle it runs fine only when giving more than quater throttle it does it backfire through the intake!! I am stumped me and my friends have no idea whats wrong woiuld love some input thanks!!!
Old May 12, 2006 | 05:23 AM
flyin ryan's Avatar
Might want to check the following:
Crossed and or arcing ing.wires
Cracked or arcing distributor cap
Mis adjusted valves
Worn cam lobe /s
Good luck hope its an easy one for you.
Ryan
Old May 15, 2006 | 02:50 PM
NWDragRacer's Avatar
Mis adjusted valves
Worn cam lobe /s
Ryan
Sounds like the cam is wasted. How did you break it in?
Old May 15, 2006 | 07:54 PM
TwoFast4Lv's Avatar
Old May 17, 2006 | 07:10 PM
YenkoST's Avatar
Either that or you are running really really rich causing it to backfire.
Old May 17, 2006 | 08:40 PM
98TADRIVER's Avatar
when one of my cars jumped time badly it did that. but go with the easy stuff first!!
