400 sbc flywheel
I need the smaller 153 teeth flywheel right and the 10.5 pressure plate will bolt up ? Also I was trying to save money and use my stock bell housing wich is the 403 so that doesnt fit over the 11 inch flywheel. .So I'm needing the 153 400 sbc flywheel ??? Any of ya guys have some advice Let me no. I geting excites to get this 406 on the road but man think I should of went with a automatic ! But love those 4 speeds Too. Thanks and time Andy Z2869302@msn.com GM makes two 153 tooth light weight flywheels. One is neutral balance #14085720 the other is for externally balanced 454 #3963537. A good race shop should be able to match the 454 flywheel offset balance to your original flywheel if it is indeed externally balanced. If you find no offset weight on your 168 tooth flywheel, use the neutral balance GM flywheel.
Mcleod (714-630-2764) makes bolt on counterbalance weights for their flywheels. That's another option if you indeed need an externally balanced flywheel. I'm sure they can match the weight of your 168 tooth unit.
Steve
I need the smaller 153 teeth flywheel right and the 10.5 pressure plate will bolt up ? Also I was trying to save money and use my stock bell housing wich is the 403 so that doesnt fit over the 11 inch flywheel. .So I'm needing the 153 400 sbc flywheel ??? Any of ya guys have some advice Let me no. I geting excites to get this 406 on the road but man think I should of went with a automatic ! But love those 4 speeds Too. Thanks and time Andy Z2869302@msn.comSteve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
I need the smaller 153 teeth flywheel right and the 10.5 pressure plate will bolt up ? Also I was trying to save money and use my stock bell housing wich is the 403 so that doesnt fit over the 11 inch flywheel. .So I'm needing the 153 400 sbc flywheel ??? Any of ya guys have some advice Let me no. I geting excites to get this 406 on the road but man think I should of went with a automatic ! But love those 4 speeds Too. Thanks and time Andy Z2869302@msn.comMy $.02
I think you would be better off selling the 10.5" clutch and getting a 11" assembly. With the torque the 406 will make you'll likely find that you will be able to burn through the 10.5. I had a Centerforce Dual friction behind my ZZ4 and it was not enough. I smoked it several times before going to the 11" setup.
