305 build up
im not so much looking for the 425hp monster as just something thats gonna kill ricers and pre 05 mustangs
yeah id like to see a good power sellers name for ebay thanks
http://cgi.ebay.com/ebaymotors/BBC-C...QQcmdZViewItem
seems to be good quality....so far it's performing just fine on my 355...
For what your looking for (something to beat stupid looking ricers) a 305 can be just the ticket. I have one in a 82 Z/28 that I have a lot of fun racing around with, I believe I described the modifications in another post of this thread.
Along with the 305 camaro - I have a firehawk and a corvette -
Here is the point I am trying to make- yes the 305 is slower than the firehawk or corvette, however I have the most fun blasting it up and down the street racing ricers. Sometimes the most fun can be had with something that isn't the sate of the art LS engine - but rather with a mild 305.
You'll need to address everything on that engine, and I mean everything, as your faced with one bottleneck after another.
First, the MOST IMPORTANT thing to making power on these cars is the exhaust. You'll want good quality parts that flow well. Shorty or long tube headers wont matter much at this power level, just make sure they're at least 1 5/8" primaries with a good collector. STAY AWAY FROM THE EDELBROCK CRIMP TYPE COLLECTORS! Y-pipe should be free flowing and as large as possible. Buy headers for a TPI car, as they'll have a larger y-pipe and will eliminate the butterfly valve in the passenger pipe. Catback should be at least 3" with a good flowing muffler. Magnaflow, Dynomax, etc. NOT FLOWMASTER.
Second, address the induction. Forget about the stock CCC QJet. They can be made to run, but require $, time, and patience. Do yourself a favor and select a good 600-650 piece on top of Edelbrocks Vortec Performer RPM intake (see below). Open element aircleaner is OK.
Finally, cam, compression, and heads. Do all 3 at the same time. Comp Cams XE 256 and XE 262 work well in the 305s. Buy the cam kit, not just the cam. Look around in junkyards for late model GM vans. From 96-02? the 305s had good cylinder heads that can be had for pennies. You will need an intake designed for the Vortec heads. Mill them slightly and install a thinner head gasket.
The above mentioned parts should make for a strong 305, and produce just under 300HP. Combine that with a 2400-2600 stall (try to source an S10 converter from GM) and some 3.42 or 3.73 gears (cheaper to install complete rear end from donor car) and you should have a fairly quick car.
Just get some world heads and port them out. Have fun...thats the name of the game.
I am interested because I would like the see the results of a aftermarket system on a 305 with mods that can keep up with the setup. I was really looking into the FirstInjections setup since it is still TPI but we'll see what happens. PM me. Thanks
Oh and you can't forget the thing all gearheads hate to hear more than building a 305....STROKE IT TO A 335!!!! LOL Release the hate mail!!!
thanks guys
im gonna get some midlength deader and dynomax catback first
then a carb and intake.
should i go with performer or rpm intake?
A Performer RPM I think is a little taller.
Face it dude your 305 is better off as a boat anchor at the bottom of the st. Johns River. The bores are way to small to put a good breathing set of heads from a 350 on it. Dude go fine a one piece rear main 350 block and stick it on a stand a go with it, drive the 305 till you blow it, buy then you should have a nasty 5.7 ready to install. I bet the MOST power you can make with that 5 liter salt shaker motor as right around 375 HP..... Thats flywheel power to. WEAK!
Face it dude your 305 is better off as a boat anchor at the bottom of the st. Johns River. The bores are way to small to put a good breathing set of heads from a 350 on it. Dude go fine a one piece rear main 350 block and stick it on a stand a go with it, drive the 305 till you blow it, buy then you should have a nasty 5.7 ready to install. I bet the MOST power you can make with that 5 liter salt shaker motor as right around 375 HP..... Thats flywheel power to. WEAK!Build your 305 and have fun with it- my 82 is setup basically for doing what you describe, and I have a blast driving it. I built it on the cheap and have had good luck with it.
What I do with it is race ricer cars when I get a chance - every now and then you can find a stock 5.0 mustang and that makes for a good fun race.
Check out thirdgen.org there are a couple good running 305's drivers on there for example this thread.
http://www.thirdgen.org/techboard/or...-305-does.html
