Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
View Poll Results: which one should I go with...bigblock/smallblock?
bigblock
69.77%
smallblock
30.23%
Voters: 172. You may not vote on this poll
bigblock or smallblock.....
Old Oct 25, 2006 | 06:51 AM
  #41
cwaldt's Avatar
Hey, when is your planned move to South Carolina going to take place.
Old Oct 25, 2006 | 11:57 AM
  #42
coolchevy's Avatar
the best of both worlds, aluminum small block with big block displacement !
Old Oct 25, 2006 | 02:42 PM
  #43
DRVETTE's Avatar
7 Second Club
Heres some info for ya. If big blocks are the big dog on the block then how come in the NSCA and the NMCA, strictly race cars, the small blocks with turbos are the cars that have to weigh in the heaviest and have the most restrictions on them. They clearly make the most HP. again in certain applications if your planning on making over 2500hp then id go with a big block. But right now the big guns in those divisions like Pat musi and vinny budano run big blocks and if the turbo guys wernt restricted they would clean there clocks, and they have, thats why they restricted them. Not to long ago a guy with a twin turbo rob reager, beat up on musi and his 700 plus ci big block on 3 stages of nos with his 388ci TT set up that he ran all year long no maintanence, musi on the other hand went thru several motors trying to beat him. Then they changed the rules. Thats funny to take, a big block guy crying to limit the TT guys. Pathetic. One other interesting FACT, theres a big block in every trash truck made. Thats a good thing for that motor.J/K
Old Oct 25, 2006 | 07:29 PM
  #44
cwaldt's Avatar
BBC is better for most people. If you've got enough money you can get alot of hp out of a 6 cyl. But for the budget racer the hp to $ ratio is greater in the BBC than SBC route.
Old Oct 26, 2006 | 10:44 AM
  #45
NRC-Motorsports's Avatar
we have hit a couple bumps in the road... so as of right now i dont have an exact date... if we can clear up some issues were having with the land and our building, then we would still try and get down there by the end of the summer and try to be up and running by the fall...we'll see.. its getting cold up here in ny and i really am sick of the cold..lol...
jay
Old Jan 9, 2007 | 11:28 PM
  #46
Quickin's Avatar
Originally Posted by TTSSZ
The cool thing about superchargers / turbochargers...
every 14lbs of boost is like double the displacement.
350ci -----14lbs boost---is like-----700ci.
On the plus side also, when your driving mello you can still get the 346 mpg.
Actually MORE than doubles it, on an 8 cyl. engine anyway.
Also, is your TT LS1 an actual LS1 block and heads or newer type?
Old Jan 11, 2007 | 09:43 PM
  #47
TTSSZ's Avatar
Its got the stock 02 ls6 block, st II lq9 heads a mild cam.
At 8lbs of boost it puts out twice the power of my 427 and gets twice the mph.
Old Jan 23, 2007 | 12:29 AM
  #48
TwoFast4Lv's Avatar
If money and emissions is no mater it is a no brainer.
More cubic inches and more strength the BBC wins hands down
Old Jan 23, 2007 | 05:37 PM
  #49
KENS96M6's Avatar
I have looked at all the combos. N2O, turbo, blower. Some of the turbo SB do put out big power but big turbo setups cost more than a deceint BB motor and N20. Not to mention the fitment issues with a V-8 turbo. Hell maybe he should go with a V-6 Buick and turbo as cubic inches dont matter with turbos.
Old Jan 24, 2007 | 05:18 PM
  #50
Quickin's Avatar
Yeah, like 2,300 FWHP, daily drivers. Gotta love it.
Old Mar 11, 2007 | 03:05 PM
  #51
1970judge's Avatar
SBC
Old Mar 14, 2007 | 01:35 PM
  #52
GMCRACER's Avatar
Racing-Following NMCA Extreme Street over the years....
This is what I have come up with... Mind you these are motors that ride the edge... and this is just my opinion....
Small blocks can run the numbers (ET wise), and even out run bbc's if set on kill with the weight they can run at... but they tend to break often... (burn up pistons)
Big Blocks don't need to be on all out kill, nor can they... The 10" tire, no wheelie bars, and weight they run at seems to keep it a level field.... They tend to run more MPH....
On a side note - Big Blocks tend to be hard on valve train....
Through my racing years I have found that Small blocks hate me... I have burnt up more than I can remember... I have run just as quick with them.... but I have also thrown a lot of burnt up blocks in the trash....
I am sure this is too much information and I am bored....
Old Mar 14, 2007 | 08:07 PM
  #53
DeltaT's Avatar
I voted small block because your engine compartment is pretty tight. If I were starting from scratch, I'd look at a big-inch LSx-based smallblock with nitrous. Like 440+ cubic inches. Check out the new GMPP LSx performance block for under $2000...
Jim
Old Mar 16, 2007 | 07:08 AM
  #54
TTSSZ's Avatar
Jim
Nitrous is a pain in the *** on the street, haw bout turbos.
then all you need is a 346ci.
Old Mar 30, 2007 | 01:26 PM
  #55
RussStang's Avatar
How does it double it at all? I certainly wouldn't expect it to. If you are running 14.7 psi of boost, that in no way means you are introducing an additional atmosphere into the cylinder. Boost is a measurement of restriction at the intake manifold, and only increases cylinder filling due to the greater pressure differential between the intake and the cylinder. There are very few engines out there running anywhere near 200% volumetric efficiency, boost or no boost. Care to enlighten me on why my thinking is wrong?
That doesn't tell me that big blocks are worse than small blocks. That only tells me turbos make big power. Strap a set of turbos on a well built big block, and watch all of the SBC guys start crying.
To the original poster, I would go big block. Obviously aluminum would be the preference, but even if I only had a cast iron one around, I would still drop the big block in there. Big blocks are becoming a rarer and rarer breed, and I think the coolness factor would be enough for me. Plus, there is that instant torque feeling that has been mentioned in this thread before. If it needs to be streetable, just don't go ape **** with the cam. Even a mildy built BB is going to make substantial power.
Old Jul 25, 2007 | 11:02 PM
  #56
rat454's Avatar
Big block! and yes size matters!
Old Jul 26, 2007 | 03:34 PM
  #57
Stroked96Bowtie's Avatar
I voted big block as I have a complete 468ci ready to go into my project..in hindsight I wished I picked something to put it in that didnt weigh 4500lbs...but have always had an eye for the mid-80s trucks...good thing is since its a BBC with even the extra wieght I should be able to outrun 95% or more of whats out on the streets..its a 10.5-1c street motor.
Typically BBC stuff is going to be more expensive too...budget is always a driver.
Good Luck!
Old Aug 11, 2007 | 01:18 AM
  #58
ZONES89RS's Avatar
In-Zane Moderator
Originally Posted by zigroid
turbo bbc
x100!!!
