Street Performance
Thanks Guys.
Josh
The shop that does my engines just built a good 406 with a procharger at 11 psi and a set of canfield heads. On 93 pump gas, it made over 530 rwhp without an intercooler, and has already run 133 mph in the 1/4 in a 3500 lb Chevelle.
Derek
fabricated manifolds and exhaust with mild steel, a/r on compressor is .68
a/r on turbine is .92
pushing 15+ psi making close to 750+ rwhp on pump gas, in a 3rd gen camaro with ath400 and 9 in rear
Late model 95 vortec roller block, cc 210/225 .545/.550 lift cam
pro top line 190cc heads with 64cc chamber, 3.75 eagle crank int. balanced
and -22dcup pistons,5.7 i beams, PP single plane intake, and damper
CSU prepped 750 DP carb. and EV bonnet and vac pump,
on a reg, drivable car that has run low 9's but has no cage and the owner sand bags it at races,
more street racer than anything
unless u get on it , u really dont know it is anything more than another 14 sec
IROC
