Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
gm guys in here
Old Aug 26, 2006 | 10:49 PM
Nemo02Z's Avatar
Default gm guys in here
Got a question but not sure where to go to ask so here we go. we have a 97 4.3 motor out of a gmc pick up, stupid us we did not mark the rods when we dropped them out of the motor, no big deal we thought, now that we are putting them back in we get them in torque them down to about twenty pounds or so and the crank will not turn over locked tight. we know its not the crank, we thought it might be at first so we got another one, now question is this, theses rods have gma and gmb stamped on them is there a certain order they have to go in or do you think that since they use heat to put the valve head back on the rods they warped the rods.
Old Aug 27, 2006 | 03:17 PM
Nemo02Z's Avatar
Here is another possibility could it possible the the pistons and rods are matched to each other specifically and when the shop put them back on they mixed them up. anyone,any thoughts on this
Old Aug 27, 2006 | 06:19 PM
8a8mfh's Avatar
Valve heads on the rods? Hmmm.
Look on the big end of the rod, there should be a bevel on one side, this goes toward the crank, there is no to little bevel on the other side of the rod big end, this side goes toward the other rod on the journal. Make sure the mark on the pistons still face forward.
This is assuming everything is right. You might have the wrong size bearings. Did you check the clearance?
Old Aug 27, 2006 | 07:56 PM
Nemo02Z's Avatar
Thats what i meant piston, just checking if anyone knows more about these than I. Everything is good except when we start to torque the rods down the crank can no longer turn over feels like something will break this is what lead us to believe the rods go in a certain order or they go to a specific piston and the shop got them mixed up. and these rods are not marked in anyway other than GMA or GMB
Old Aug 27, 2006 | 09:39 PM
8a8mfh's Avatar
GMA and GMB mean nothing to you, me, anyone except for the people who forged the rods in the factory.
AGAIN did you check the bearing clearance? Did you make sure the bevel on the side of the rods big end faces the crank and not the other rod?
What about the caps? you say they are not marked any other way right? no stampings?
Do you know if the caps are on the rods they came off of?
The caps have to be on the rods they were originally on, in fact you should not have a disassembled engine in your presence that doesn't have the rod caps AND rods numbered.
If you have the caps and rods mixed up you are going to risk damaging the pistons getting them back off the rods, and the rods are going to need to be reconditioned.
Old Aug 27, 2006 | 10:23 PM
Nemo02Z's Avatar
Crap hoped that was not the case, appreciate it.
Old Aug 27, 2006 | 10:24 PM
1bad71's Avatar
rods are all the same! they can go into any cyl. you need to check 'all the clearence's. do you have a spec sheet from machine shop? this will tell you what everything is at.
if your not sure how to read the sheet? go to any performance shop or online and get a manual! "how to rebuild your small block chevy" the best 30 bucks you'll ever spend.
Old Aug 27, 2006 | 11:09 PM
Nemo02Z's Avatar
well your right rods are all the same but after looking at the caps they are different, three have a tall bevel and three have a short bevel. Now all we have to figure out which caps go to which rods. All parts are new all other parts have been machined. The info on the caps might have given us the break we needed will let you know, thanks
 Michael S. Palmer
Old Sep 1, 2006 | 09:11 AM
LS199CAMAROZ28's Avatar
rods can go in any cylinder until u get the rods and caps mixed up.
Old Sep 1, 2006 | 04:43 PM
Nemo02Z's Avatar
Thanks got them figured out, until now did not know it made a big difference when you get the caps mixed up.... Let this be a lesson to everyone make sure you stamp the rods and caps when you pull them from the motor
