Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
New engine backfiring - Will not start?? HELP
Old Sep 19, 2006 | 07:20 PM
detroit_903's Avatar
Default New engine backfiring - Will not start?? HELP
Just recently installed a 350 sbc in my 67 camaro. Went to try and start it up for the first time after the install and it would not start. Keep backfiring. We checked all the plugs and they are in the correct order - Does anyone know what the problem might be???
Old Sep 19, 2006 | 08:12 PM
My01SSCamaro's Avatar
I think i know what your problem is, try checking to see if your distributor is 180 out, put #1 on tdc firing and take off your cap if your rotor is facing backwards then it is 180 out, its trying to fire on the exhaust tdc stroke rather than the compression stroke, hope this helps ya
Old Sep 19, 2006 | 10:08 PM
TimTaylor75's Avatar
^^^Sounds about right to me as well.
Old Sep 20, 2006 | 11:47 AM
AMS69's Avatar
i agree
Old Sep 20, 2006 | 12:23 PM
69chevy's Avatar
That's usually the case if everything else such as the sparkplugs like you mentioned checked out ok.
Old Sep 20, 2006 | 01:13 PM
Default Re: thanks
Yeap that was defently the problem. Thanks everyone for the help. ---Mike
