H beam rods
its a load thing the longer the rod the less load on the cylinder bottom as the crank turns and the longer the piston dwell is ( time the piston stayes at the top of the bore ) 6 inch works well in all kinds of things for a SBC if you can use it -- jz
I would go H-Beam. I'm putting a set of scat h-beams in my 400. I found them on ebay for around 320 bucks. Build a stong short block and that way you won't be hesitant to beat on it at the track or on the street.
