Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
View Poll Results: Mild Steel or Chromoly
Mild Steel
1
12.50%
Chromoly
7
87.50%
Voters: 8. You may not vote on this poll
New K-member Question
Old Oct 17, 2006 | 09:41 AM
cwaldt's Avatar
Default New K-member Question
Should I go with mild steel or chromoly. I figured the mild steel would be stronger but I'm not 100% sure. If the chromoly is as strong or stronger I'll go that way for wieght reduction.
Old Oct 18, 2006 | 05:58 PM
ulakovic22's Avatar
I would go with chromoly. It's lighter and should be stronger than mild steel. It will flex more, and will tend to bend rather than break like steel does.
Old Oct 21, 2006 | 11:15 PM
TimTaylor75's Avatar
I've been trying to figure this one out as well (check my poll/thread in the Handling section). I think I've finally made the decision to go with a regular mild steel and pick up Madman's motor plate. Mainly, due to the his suggestion of using a k-member with no motor mounts to allow for more header clearance. Granted it will add a bit in terms of money, but the added benefit of more space and strength of the plate setup will hopefully be the best of both worlds.
