Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
350HO w/ TPI
Old Oct 28, 2006 | 01:35 PM
everything_forgotten's Avatar
Default 350HO w/ TPI
Im ordering this engine for my 91 TPI camaro >tomakethels6intownfrown<
http://www.jegs.com/webapp/wcs/store...tegoryId=10763
And im going to upgrade the TPI system (edelbrock) etc... i still have the factory ECU etc.
would it be a hassle to mount this engine and new intake in my car w/ any problems? like would the engine run right, would the computer handle it right?
would i have to invest in a new ignition system? would i have to get a computer-controlled cam etc...
Old Oct 28, 2006 | 09:17 PM
1989GTA's Avatar
That motor has Vortec heads. If using TPI make sure to get a manifold that fits Vortec heads. What motor is in the car now?
Old Oct 29, 2006 | 01:17 AM
Randy_S's Avatar
If your going that route, why dont you just look at Scoggin Dickey and check out their Vortec TPI 350. The numbers are bigger and the heads are already matched to the TPI intake setup.
http://www.sdpc2000.com/catalog/1578...rip-Engine.htm
That is the link to the motor!
Old Oct 30, 2006 | 10:43 AM
its the stock 350 w/ tpi.... it runs fine.. though i wish to have a new engine but the same set up...
ps - the manifold is for vortec heads only.. other than the intake fitting etc.. what other problems would occur? like my stock ecu not reading the cam.. or the compression not right, wrong ignition etc...
