NOS setup for SBC?
F UP....
1 trick that I personally use when helping buddies is to put lights in line with the solenoids, so you can see if everything is running correctly. Bottles off, fuel lines plugged. Also watch your RPM, when the retard comes on you should see it. When everything is firing the way it should, hit the track! ! !
Tuning can also be a big issue, although many companies set their kits up a little rich to be on the safe side.
Good luck!
Derek
