Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Is there another header besides the 2455 for bbc
Old Nov 4, 2006 | 08:15 PM
Rundeep66's Avatar
Default Is there another header besides the 2455 for bbc
Is there anything else I can use that is a little bigger than the 2455. the header is only a 1.875. This header was not intended for the swap but it wirks. Is ther anything else out there maybe with a 2 1/8 tubes and 3 1/2 out
Old Nov 4, 2006 | 10:53 PM
machinistone's Avatar
What is the application?
Old Nov 5, 2006 | 12:38 AM
Rundeep66's Avatar
BBC in a F body 572
Old Nov 5, 2006 | 10:06 AM
ulakovic22's Avatar
Hooker makes a 2285 and 2287, but I'm not sure how they fit. They are a 2.125 primary made for older BBC camaro's, Nova's and Vega's. Not sure about the price tag though. With the 2455 you get 2 in primaries and the driver side slides in no problems, passenger side is the only one that needs a little work and they're only $150
Old Nov 5, 2006 | 09:36 PM
Rundeep66's Avatar
thank you
Old Nov 23, 2006 | 05:19 PM
1969CAMARO's Avatar
you will have to notch the bottom of the header flange prior to installing them, dont buy them coated , you will break the coating grinding on them, the 502 and 572 use big head bolts and will not clear..
Old Nov 23, 2006 | 10:48 PM
JUICED96Z
Guest
Posts: n/a
KOOKS? Can't remmeber the specs but I know the make them for a BBC in a 4th gen.
