Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Solid Roller Springs
Old Jan 15, 2007 | 03:25 PM
Juiced's Avatar
Default Solid Roller Springs
Crane 99876
Outer Diameter 1.565
Inner Diameter 1 1.146
Inner Diameter 2 0.740
Seat Pressure @ Installed Height 190 lbs @ 1.950
Open Pressure and Height 552 lbs @ 1.250
Coil Bind 1.200
Average Spring Rate 504 lbs/in
How would these do with a .750 lift cam?
Old Jan 15, 2007 | 04:34 PM
mrdragster1970's Avatar
6 & 8 Second Club
I'm no expert, but my .788 cam needed 240-250 lbs on the seat.
I would call Crane before you hurt something. Be careful, good luck.
Old Jan 15, 2007 | 08:01 PM
Juiced's Avatar
Thanks,
They aren't goin on the heads, i had them laying around and they are no and i just wanted to know if the would be of any use in this build.... guess not.
Old Jan 15, 2007 | 11:51 PM
Cali99SS's Avatar
I think you would be in to coil bind. Installed height is 1.950 and bind is 1.200. I may be off here but I think you want to stay .050+ away from bind height.
Old Jan 15, 2007 | 11:53 PM
UGotBeaT's Avatar
.060 away from coil bind generally
