Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Problem with mallory ign Box,
Old Feb 17, 2007 | 05:13 PM
My01SSCamaro's Avatar
Default Problem with mallory ign Box,
I just installed a Mallory HyFire 6a box and i wired it exactly like it said to i have a brand new mallory dist. and wires, it will start and idle but every now and than its like i just tuend the key off and back on real quick and some times it will just die i can watch the led light when it does this and it just goes out completely like i just turend it off i have checked all my connections over and over again i soldered everything, it almost like i have a loose connection but i have checked it all over many times, im not sure what it could be, when its not doing this it works perfectly no problems, need some help
Ryan
Old Feb 18, 2007 | 05:14 PM
Any one ever run into this problem??
Old Feb 19, 2007 | 12:16 AM
transam5.7lt1's Avatar
I had a situation with one, is yours the one that has the RPM/rev limiter dial on the side? I had one installed on a friends car, it is a 1986 monte carlo ss, car would act as if it had a rev limiter set at one specific point, it would not respond to any changes on the dial and it wouldn't run right... it took us a lot of guessing and time to find out that the damn box was faulty... it was removed and replaced with stock HEI ignition, car has been running like a champ since then... I was warned before ordering the box. There was plenty of people who had issues with them, I personally have gone with MSD 6A in my 1975 camaro, and a MSD 6AL in my 1994 Trans Am. I apologize for not being of much help, but I do think those boxes from mallory have some sort of a defect built in them.
Old Feb 19, 2007 | 12:24 AM
Thanks, i will be giving them a call tomarrow whenn they open up and see what they have to say, i switched mine back to just the hei dist, not and it runs fine now so i think there is something wrong with the box, hopfully i can get anotherone and not have anymore problems, i knew i should have went with a msd
Old Feb 19, 2007 | 12:27 AM
I know that feeling, at least you found out its in the box. Good luck man.
