Need an opinion SBC
THIS PLUG HAS ABOUT 30 MILES ON IT!
350 SBC
I have had trouble with cylinders #2 & #4, they fire but not all the time. I can glass bead the plugs, reinstall and they work better. I looked at the intake gasket and it looked good. I do have molly rings and may have not treated the cylinder walls correctly before installing. The engine has about 8k miles.
What do you guys think?
+1
If you use Felpro MLS intake gaskets nothing getting past those, the thread sealent is mainly used to keep oil from coming out top of the bolts and setteling in the manifold.
..and it looks like youve burned a little coolant in the 4th cylinder, what head gaskets did you use?
I think I will have the heads inspected / reground and look into a short block built by a pro. I haven't removed the pistons yet but might tomorrow.
