355SBC ideas on hp?
355
dart 215cc iron eagle heads 64cc
RPM airgap intake
Mighty Demon 750
cam is 480/480 lift with 1.5, and 234/234 duration.
i have 1.6 rr on the motor, any idea what the new lift would be?
compression should be right around 10:1
I have a MSD digi 6+ that i will be putting in the car, my question is what would be the best distributer setup to get for it? i have a brand new HEI accel vac adv that was given to me with a accell HEI cap.
Also, any ideas on HP/TQ? it will be running through a t56 trans and a beefed up 3.73 10 bolt.
Anything you guys would change about this motor?
Im used to building motors back to stock specs (60s chevy showcars) im not very familiar with tuning higher performance engines.
Thanks again.
-slim
I run the factory ignition without problems. Heads seem a little large for a 355 but if you already have them then I would run them. Try for a .035" quench to keep detonation under control and a better burn.
