Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
BBC 454 Oil Level
Old Apr 22, 2007 | 10:40 AM
go300mph's Avatar
Default BBC 454 Oil Level
I have a dip stick with pecker tracks on it form somebody elses welder, humm How do I know how full it really is? I know the oil pan must be NOS since it only holds 5 quarts , ??? is there a 5 quart BBC 454 out there? Mine is a 1975 oiut of a chevelle.
Any help anyone?
MIck
Old Apr 22, 2007 | 11:05 AM
mrdragster1970's Avatar
6 & 8 Second Club
If you think they changed the one u have, buy a stock replacment.
Cheap insurance to not starve anything, since we all know you will NOT be taking slow steady launches, stops & turns.
Old Apr 22, 2007 | 01:04 PM
go300mph's Avatar
Thanks Mr Dragster but Not sure anything else would fit , i suppose I forgot to tell you it is now in a 1984 chevy 1 ton used to tow the trailer around. If I put in 6 qts it drips out the pan gasket so that means the oil level is too high I am sure the crank sticks down into the pan at least an 1" , I am going to research some more.
Mick
Old Apr 22, 2007 | 01:38 PM
8a8mfh's Avatar
Any help anyone?
MIck
There is a 5 quart bbc pan out there, I have one in my backyard under a truck topper. It's 9" x 8" x 7.5" deep.
The 8 quart pan in my one ton is 11" x 8" x 8.5" deep.
These are the sump measurements.
Old Apr 22, 2007 | 03:08 PM
go300mph's Avatar
Am I coorect that the crank should absolutely NOT dip into the oil in the pan, thus the entire idea of a windage tray right? so I would assume that the oil level needs to be below the lowest point of the crank, Can anyone tell me how far below the oil pan rail on the block does the crank hang down?
