Installing tranny on SBC help!
Should I stab the tranny and bellhousing as a whole or put the bellhousing on and then stab the tranny?
First off I realize that with something like my t56 is much easier to go bellhousing on and then tranny but thats when your t/o bearing is already centered on the shaft. The t/o bearing with this tranny sits in the clutch fork making it hard to be centered. I really hope someone can HELP me here. I have had the bellhousing on and tried stabbing the tranny multiple times but it is simply to hard this way. This transmission uses a clutch for the works with an external slave cylinder which is the way most of your older trannys work. It looks like if I attach the bellhousing to the tranny it will be easier. I already pulled the exhaust out of the way and will be giving it a shot trying the bh and the tranny together method. Thanks for any help...
Josh
Josh
