Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
350 major problem, need help!
Old Jul 17, 2007 | 01:09 PM
camaro84's Avatar
Default 350 major problem, need help!
my 350 engine recently started knocking, so i took off the valve cover because that is where the sound is coming from and the 4th cylinder exhaust valve,spring,rocker,pushrod is not moving when the motor is running. what are the possible problems?
Old Jul 17, 2007 | 01:23 PM
mzoomora's Avatar
14 Second Truck Club
A flat cam or a broken lifter.
Old Jul 17, 2007 | 01:56 PM
Jon5212's Avatar
Wow... Cam lobe is broken? I would think even with a collapsed lifter it would still move a little bit? Maybe I'm wrong...
Old Jul 17, 2007 | 02:37 PM
jmm98LS1's Avatar
Probably wiped cam lobe and chewed up the lifter. I lost the #5 exhaust lobe (comp xtreme energy) on my old 355 after just 12k miles. The lifter was missing nearly .25" and the lobe barely had a ramp left. It still moved the valve a tiny bit though.
Old Jul 17, 2007 | 02:51 PM
camaro84's Avatar
ok, if i just replace the cam and/or lifters, would i have to have the heads machined or would it be alright?
Old Jul 18, 2007 | 09:05 AM
jmm98LS1's Avatar
Never re-use flat tappet lifters on a new cam, always get new ones. You don't need to do anything to the heads.
