holly tuneing
That's the short sweet version, it is an art to get it perfect.
Then the weather changes.
If you tried to look at our sections for two seconds you would have seen this section:
LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > Small Block & Big Block Chevy Specific
So from now on look around a little bit, use the search button, and read some sticky threads before your post.
But good luck with your Holly!
Thanks,
Craig.
LS1TECH.com Staff
There are 3 circuits, or 4 depending if you consider the accel pump a circuit, in a holley carb and each one of those circuits can be tuned independently. Of course, depending on what it needs, or what its problems are.
Theres a great book "how to tune holley carbs" by Alex Walordy. I suggest you pick one up. Theres just too much info to try and post it in a couple paragraphs on a forum.
The book addresses all the important aspects, such as choosing the correct power valve (very important, and most people have no idea how to) idle tuning, throttle blade drilling, metering block modifications including emulsion tube mods and a bunch more. You'll need to read it 2 or 3 times. If you any specific questions shoot me a PM. I've been tuning Holleys for 20 years.
