Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Intake is leaking need help 350 SB
Old Aug 18, 2007 | 05:10 PM
1FSTLS1's Avatar
Default Intake is leaking need help 350 SB
Just got this car. The intake is leaking smells like gas mixed w oil at the front corner of the intake. Is this common? The guy must have done somehting wrong. Should I just take the intake off and reinstall w some RVT gasket maker??? Please help new to carberated motors....
Old Aug 20, 2007 | 12:21 PM
Ryan02SS's Avatar
More than likely he used the crap gaskets that came with the manifold to seal the front and rear of the intake manifold. They are junk and always seem to leak. Remove the intake and clean the area very well. Apply a nice bead of RTV and reinstall intake. I've yet to have on leak doing it this way.
Old Aug 21, 2007 | 12:47 AM
ZONES89RS's Avatar
In-Zane Moderator
+1, i dont know anyone that uses the front and rear seal, it is a PIECE!!!
Old Aug 21, 2007 | 06:25 PM
67rsss's Avatar
Did you check the torque on the bolts? Failing that, you are pulling the intake, luckily, not a hard job. I like to use blue RTV on coolant passages. If you buy premium gaskets, you shouldn't need the RTV though. For the front and rear ledge of the valley pan, DO NOT use the little cork or neoprene gaskets in the kit, just build up a nice layer of RTV, I like to use the orange for this, but the black works good too.
Old Aug 22, 2007 | 12:05 AM
ZONES89RS's Avatar
In-Zane Moderator
Orange Pooky
F
T
W!!!
