Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Single turbo Setup
Old Sep 6, 2007 | 10:44 AM
UDL0SE's Avatar
Default Single turbo Setup
I am looking for the headers and cross over pipe to do a single turbo setup on a 434 in a 3rd gen camaro. This will be a blow through with a 750 dominator..
Old Sep 6, 2007 | 11:04 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
It's going to have to be a custom setup. i've never seen anyone that makes a kit.
Old Sep 6, 2007 | 11:30 AM
383lt1impala's Avatar
Im Not A Big Expert But I Bet Its Not A Wholeeee Lot More For Twin Turbos
Old Sep 6, 2007 | 12:13 PM
Dragframe's Avatar
how could you really say that? You have to buy two turbos, not one (the most expensive piece in a damn setup), two wastegates, spend more time troubleshooting any problems because now there is more parts for things to go wrong.
Twins are player tho... .lol
Old Sep 6, 2007 | 12:31 PM
JUICED96Z's Avatar
A buddy of mine has twin T-88's. More expensinve then a single 91 I bet hahaha.
Old Sep 6, 2007 | 12:40 PM
UDL0SE's Avatar
Wow thanks for the very quick replies. I have been thinking about the twins but just do not know if I want the headach or not.
I just might have to do the twins...
Anyone here have a picture of a 3rd gen with twins?
Old Sep 7, 2007 | 02:39 PM
Dragframe's Avatar
you can buy a "kit" for twins on those cars
Old Sep 7, 2007 | 03:41 PM
NemeSS's Avatar
yes, twins with t3 60-1 turbos,
used akit of ebay for friends car, ebay alum.heads, headers were 321 ss
fit really good for use with 38mm wategate, per header, also blo thru. with csu carb., th400 3500 stall, with anti-ballon plate, 9 in. with 3.10 gears.
still waiting on parts to complete, also using large fmic.
car is 86 camaro with tub. kmember
Old Sep 8, 2007 | 04:57 PM
Josh@KY-Turbo's Avatar
I am working on fixing that.
Old Sep 8, 2007 | 05:01 PM
GrahamHill's Avatar
There are a few 3rd gen race cars with the stock front suspension and twins on both small and big block engines but they are all custom done.
Old Sep 11, 2007 | 12:59 PM
88blackgt's Avatar
You could fab up a kit if you're good at welding. Flip an old set of headers and get some pre-bent tubing, there are lot of places online that sell it. A big single would be cheaper and make similair power. Theres also plenty of places that sell manifolds, then would just have to make the crossover pipe and the rest of the hot side. Also look into s400s if you want to stay big single, theyre a fairly common turbo that can be found somewhat cheap.
http://www.theturboforums.com/smf/in...?topic=96088.0 <-- not so great looking, but functional
http://www.turbomustangs.com/smf/index.php?topic=4049 <-- DIY singles
http://www.turbomustangs.com/smf/index.php?topic=39744 <-- more DIY singles
Old Sep 20, 2007 | 07:18 PM
birdflu's Avatar
If your goin to go blow through try CSU .I have good stuff to say about blows through from CSU.
Old Sep 20, 2007 | 08:03 PM
XpEdItIoUs's Avatar
That would be sweet.
Old Sep 20, 2007 | 10:43 PM
Its in the works and slowly progressing. I want the SBC setup to fit as many platforms as possible which makes designing the setup interesting.
Old Nov 30, 2007 | 09:57 AM
jhelms's Avatar
Are you going to do much of the work yourself? Who built the 434?
