Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
455 olds motor
Old Sep 23, 2007 | 09:45 AM
1FSTLS1's Avatar
Default 455 olds motor
Does any one know any thing about 455 bb from oldsmobile. Would this be a good motor to put in my 81 Trans Am. Cost is free. Or would I be better off with building a 383 stroker from my current 350?
Old Sep 23, 2007 | 10:18 AM
ulakovic22's Avatar
Use the 455. Those motors are awesome! Esp for that big *** car. They respond very well to simple modifications. What motor is in there now?
Old Sep 23, 2007 | 10:23 AM
1FSTLS1's Avatar
Chevy 350 that needs re-built. Wonder if the 455 will fit ok. I also have the shaker hood that I am worried about fitting.
Old Sep 23, 2007 | 10:43 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
455 motors are great torque monsters, but keep in mind it will be heavier than the 350 chevrolet engine.
If you want plenty of info on Olds motors, check out www.realoldspower.com
Good luck whatever route you choose!
Derek
Old Sep 23, 2007 | 11:50 AM
ZONES89RS's Avatar
In-Zane Moderator
Man, the BOP motors(buick,olds,pontiac) are such beasts on the low end, i had a pontiac 455, when i ported some 6x heads, installed a cam and intake with headers it got a crease in the top of the car on a 200 shot, ran great but it mucked up my roof.
Old Sep 23, 2007 | 03:23 PM
ulakovic22's Avatar
Physically the 455 motor will fit. I had a 79 with a 403 and I contemplated the swap as well. I called Mondello's and they said the 455 would use the same motor mounts as the 403 and wouldn't be a problem with the shaker. Worst case is you have to fix the shaker to the hood for the extra clearance instead of on top of the carb.
Old Oct 8, 2007 | 05:33 AM
1FSTLS1's Avatar
I picked it up yesterday and trailered it home. Dumped some gas in the carb put a jump box on it and it fired right up.
Old Oct 8, 2007 | 07:52 AM
Sharpe's Avatar
Lucky bastard. Always wanted one of those. Damn. In an 81, that will be a beast.
Old Oct 11, 2007 | 04:58 PM
1luckeyt/a's Avatar
The 455 will fit your drivers side valve cover is going to be really close to the brake booster. Not that big of an aftermarket though, go to realoldspower plenty of info on there. As for the ? of should you use it . oh yeah even the smog motors have massave amounts of torque. Enjoy your new lack of traction I know I did .
Old Oct 11, 2007 | 05:03 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Torque Monster = 455 Ci.
Old Oct 12, 2007 | 09:29 AM
1FSTLS1's Avatar
In search of motor mounts for this project if any one knows.
Old Oct 13, 2007 | 06:32 PM
1luckeyt/a's Avatar
Find motor mounts from a T/A that came with a 403 olds thats what I used for mine and they worked fine.
Old Oct 16, 2007 | 08:14 AM
1FSTLS1's Avatar
So when did Trans Am come with Olds 403 motor?
Old Oct 16, 2007 | 08:24 AM
ulakovic22's Avatar
I believe it was 1979
Old Oct 22, 2007 | 05:06 PM
BBATCAR's Avatar
Actually 1978 for auto California cars. My VIN numbers shows that it came with a 403 Olds, currently has a 455 but needs work. I just got the car as a restoration project car for a Bandit Clone.
BTW, the motor will fit on the 403 motor mounts, however the shaker scoop is a problem. The previous owner of this car glued the shaker scoop underneath the hood and the scoop sticks out way to far out IMO, it just doesn't look right. Carb with a small air filter BARELY fits under the scoop.
I am actually going to take this to my mechanic in a few days to see what suggestions they have on keeping the 455, shaker scoop, etc. or changing out the motor. Either way I am going to have to sink some money into the engine. Just want to get a classic car mechanics advise.
Old Oct 24, 2007 | 01:46 PM
1FSTLS1's Avatar
Yea let me know on that scoop solution?
Old Oct 24, 2007 | 02:15 PM
ulakovic22's Avatar
I beleive that you can run smaller big block mounts that will give you the clearance needed. If a Pontiac 10.2 deck can fit in there then an Olds block should fit no problem. Manifold choice has a lot to do with it as well, Performer, RPM, or Victor.
I would post a link but it would probably get removed, lol. Basically look for big block frame and motor mounts from a Toronado. Look for the part numbers online and order them repop or take your luck at a local junkyard.
Old Oct 24, 2007 | 02:46 PM
Jakes Dad's Avatar
I can only assume this free Oldsmobile 455 was built after GM lowered the compression beginning in 1971. They made so much torque GM installed it into their only venture FWD motor home.
Ashamed, I can't remember the torque in the 1970 - W-30 Olds, I sold them. Advertised as 370 hp. it was every bit of 390. You could order an aluminum case with a 4:33 gear.
Yes, install it!
An old man and his dog!
Old Oct 24, 2007 | 04:17 PM
Jakes Dad's Avatar
Ashamed so I had to look for the torque #'s try 500. Red line was 6,000 perhaps 6,200. Most of that torque was down low. Today, some would call it a good dig car.
Doctor W at Oldsmobile was responsible for the performance. Was one hell of a engine in several old NHRA stock automatic classes.
