Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Voodoo
Old Nov 5, 2007 | 03:14 PM
Sweet2's Avatar
Default Voodoo
Has anyone tried this cam?
I'm putting in a 1970 350/300hp with 10.25 to 1 compression,3.08 posi rear
Part # LUN-60101LK
Product Line: Lunati Voodoo Cam and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,000-5,500
Duration at 050 inch Lift: 213 int./219 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.468 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Old Nov 18, 2007 | 02:47 PM
Bmassie's Avatar
Default Voodoo cam
ive used the cam in a 350 in a 4x4 works great but you might want to check out the 489 504 lift it so far is the best power producing 268 cam to date with the new lobe designs it works like a big cam with the charicteristics of a small cam. But it depends on your want and needs,it is very well worth the time to check into though.
