replacing my quadrajet
And also im pretty sure this is bs cuz my dad is a dick and just says whatever will make you feel hopeless, but the question is will this edelbrock work on this car? he says it wont because it will screw the computer up? I didnt this it had a computer? but like i said my dad is an *** so tell me will it be ok or not?
The wires are a non-CCC quadrajet (non computer controlled) are typically the A/C fast-idle solenoid (or whatever it's called) on the driver's side, and the electric choke on the passenger side. On CCC controlled quadrajets there are the same wires as noted above, but with the addition of a mixture control solenoid connection (front-pass side of carb, on top) and throttle position connection (front-driver's side - vertical white connector with three wires inside). I'm not sure if the timing control algorithms in the stock ECU factor in the throttle position, but if they do then yes you will screw up how the engine runs unless you switch out the distributor for an old-school style vac/mech advance distributor.
To be honest my reccomendation would be to swap out the carb system for a TPI (~$200 on Ebay), build (or buy) yourself a Megasquirt fuel injection system (can be had for around $600), toss an in-tank Walbro 255lph fuel pump, some steel braided line to the front - and now you have a system that is infinitely adjustable, can control traction, nitrous, and timing - and you can make adjustments to the fuel mixtures with a laptop in the passenger seat while still driving!
