Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Compression...
Old Feb 26, 2008 | 08:06 PM
ZONES89RS's Avatar
In-Zane Moderator
Default Compression...
OK, my buddy has had hell with his 355 he had a shop build, it has aluminum 200cc brodix heads with 64cc chambers, the car was running on 93 octane but after failure to run worth a **** and three flat tappet cams later, i tore it apart today and found it has 2 valve relief pistons...with atleast a 1/4 inch dome, the builder claimed 10.7 to one compression...i say the 6....yea 6 broken compression rings were due to needing more octane, ill load some pics tomorrow if you guys like but i think it was more like 11.5 to 1 or so, what do you guys think?
Old Mar 8, 2008 | 12:32 AM
torquejunky's Avatar
hard to say without knowing the CCs of the dome, I just haven't put that many together to be able to "eyeball" it like that.
But if I had to guess somewhere in the 14:1 range??... dunno
Old Mar 8, 2008 | 04:19 AM
ZONES89RS's Avatar
In-Zane Moderator
Naa, it is not that big of a dome, i am just assuming a little over 11 to 1, maybe.
Old Mar 8, 2008 | 11:50 AM
Shawn @ VA Speed's Avatar
a .100 dome is around 11-1 a .250 dome is around 12.5-1 depending on deck height above piston and head gasket thickness,but either way should not be used in a pump gas motor,flat top pistons are good with 64 cc heads,usually around 10-1
Old Mar 8, 2008 | 07:56 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, it is zero decked so i am sure it was just enough to need more than 93.
Old Mar 9, 2008 | 10:23 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Agreed on without knowing what size the dome is hard to tell. My old 355 with 65 cc Canfield 195 cc heads and a 2 valve relief flat top piston came in at 9.7:1 compression. A small dome could keep it under 11:1 and pump gas friendly if the tune was spot on.
Derek
Old Mar 9, 2008 | 09:06 PM
ZONES89RS's Avatar
In-Zane Moderator
That is the problem, he cannot tune worth a ****.
