Post your ideas for a BBC here
Motor will need to be a street motor but will need to be NEAR max effort as you can get but not be a race motor, yes I know this is hard to do.
What I mean is I don't mind changing valve springs twice a year or so but refuse to have to change them after every time I cruise the car.
Car will be trailerd to the track and cruised around local areas, maybe 200 miles a year at most (have no idea honestly but not many miles).
Big hit nitrous car, heads that I have for it now are aluminum 14011077's 118.Occ, IP 295cc, C port's that I am going to have ported and converted to D ports. Intake is a Holley Strip dominator that will get more porting.
Thinking about a Merlin CNC block maybe a III that way it can grow with me for when I invest in some better heads. Headers look like super comps and are not huge, standard size, I will try and measure them Sunday.
Car is on race gas so I am not worried about that. Don't really want to run a Vac pump, want to keep it as much of a sleeper as I can from the looks area.
Have a BG 850 carb that flows 1,040CFM.
Car went 10.4@136 on a 150 shot from what I can tell and on old parts.
Would like easy high 9's on the motor with new combo.
Not in a rush to build this car, needs new fuel system, and other odds and ends, not to mention its legal to run high 11's or so.........
You already want to use an aftermarket block, so I say build a 12:1 540 cube shortblock. Add in a mild solid roller that spins it to 7000rpm. Toss your nitrous on top of that and you should be close.
Going to measure the primaries tommorow to know my options.
If I stick with these heads they are going to be ported by a pro stock porter, he will more then likley spec the cam also.
My number 1 problem is header clearance, I BARLEY have the room for the headers I have now, anything larger I am am pretty sure they will have to be custom but could be wrong.
Pics of headers here
http://s275.photobucket.com/albums/j...camaro/?start=20
Heads look like they allready have some porting but if I can get some headers from ed then I will look at some heads.
Fiance approved all the overtime I want for the car hahaha
Going to cost about what I thought it would and will cost at least what the car cost me if not more.
Right now the goal is to get the motor and tranny done by next season then winter of 09 get it hookin and caged.
Fiance approved everything
Just for a teaser the motor will be a street/race motor but very close to a race only motor, higher compression roller motor.
They built a friends 540 and I told them I wanted rouglly the same thing but something I could drive on the street some, just don't want to change valve springs and parts every weekend and they seemed to have a good idea of what I wanted.
Selling the motor and carb I have now since I can't reuse anything for this motor, intake still might work though. Headers will be to small also.
Next few months with the drivetrain out I think I am going to rewire a lot of things and hide some stuff. Don't really care if this even takes two seasons, it will be a lot of fun.
Found a push button (big sucker like something for a trans brake or something) tucked up next to the ignition stuff in the car and was long enough that you could hold it while driving even though it was jerry riged, it has one wire going to the started and another one that I don't know what it goes to yet... hmmmm weird
Wiring job was not horible but not the best. Will be able to put the coil and new ignition box under the dash along with one of the fuse blocks and hide I would say 70% of the wiring under the hood. Pulling the heater box and one of the wiring bundles is just for that so that will be nice when its gone.
Allready pulled the factory catch can (going aftermarket and will hide it).
Everything under the hood is starting to look a lot cleaner! Trouble shooting I think will also be a lot easier.
Also putting the battery in the back of the car for weight and to clean things up under the hood also.
Might be going with another 540 short block that a local has........ either way the car will have more then enough power to pretty much take out any local that does not have a full race setup that should not be on the street hahaha.
